dave205
Fuel Filter/s
Ryan
They're only plastic, designed for low-pressure systems like carbs or bikes. They can't handle the pressure of an injection system.
A lot of people use a 106 filter - it's smaller than the 205 one, and has push-on connections rather than fiddling about with banjos.
dave205
Thank you for that, ive learnt something today!! :)
i'd just stick to the 205 filter, you don't have to change it that often so fitting a 106 filter that's supposedly easier to change (but always looks crap when fitted), you can get the banjo's the correct size to fit the pipe that matches the fuel rails.
stef205
i ran those types of filters on my gti6 engine no problems but a 205 filter would look better, or a 106 gti filter as ive changed to
dave205
I think im going to run a 205 filter to be on the safe side, and mount it on the slam panel and run some hoses to it.
