JYGTI 1 2 Cars Posted December 31, 2011 Guys, I have a perfect passenger donor seat for my project car which i want to make into a drivers seat, as the bolster is warn along with some cloth. I can take this off its base frame and attach it to the drivers side frame, the problem is that the seat adjusting wheel which makes the back go up or down is on the wrong side, does anyone know how to move the wheel to the correct side and will it still work? Thank you in anticipation. Share this post Link to post Share on other sites
Anthony 1,002 Posted December 31, 2011 Whilst it doesn't strictly answer your question, you can leave the wheel on the "wrong" side and it will work fine, although it does sit quite close to the tilting handle on a 3dr subframe. The only thing that you can't fit (without modification anyway) is the lower plastic trim piece, but to be honest that's never bothered me. That's my 205 with both front seats having originally started out as passenger seats. Share this post Link to post Share on other sites
m_attt 31 1 Cars Posted December 31, 2011 can you not take it to an upolster and have them swap the cover and bolster foam Share this post Link to post Share on other sites
thug pug 7 1 Cars Posted December 31, 2011 Hi mate, I have just redone all the seats in my CTI and as said above I used the original frame and swaped the foam and cover over as these are the same on both drivers and passanger seats. I did the job myself in about an hour and its not a hard job to do and even if you don't fancy it yourself I don't think a upholster would charge much. Rab E. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted January 1, 2012 Swapping is the best way, you will find allot of the time the frames broken as well so ideal time to weld it all up Share this post Link to post Share on other sites
JYGTI 1 2 Cars Posted January 1, 2012 Thank you for your replies. I will try and change the cushions over then. Is it hard to get the metal clips/staples back into the base to keep it tight? Thanks again. Share this post Link to post Share on other sites
Pugleyrich 37 1 Cars Posted January 1, 2012 It is quite easy to get the clips back in. You will find that some may rip through the foam of the seat base when you take them off, but you can make new holes elsewhere. Perfect time to put replacement bolsters on too if they have collapsed. Share this post Link to post Share on other sites
thug pug 7 1 Cars Posted January 1, 2012 I have also used in the past small electrical cable ties and do just as good a job as the metal staples. Rab E. Share this post Link to post Share on other sites
jeremy 70 Posted January 4, 2012 Instead of using the original hog rings, I used electrical copper wire say 2.5mm twisted together with pliers then cut neatly. Share this post Link to post Share on other sites
JYGTI 1 2 Cars Posted January 6, 2012 Thanks guys. I did it and it has come out really nicely. Thanks again for your help. Share this post Link to post Share on other sites
Henry Yorke 269 3 Cars Posted January 7, 2012 Pics please Jonathan! Share this post Link to post Share on other sites
stufarri 98 3 Cars Posted January 9, 2012 Stick some heated elements in there too - nothing better than this in the CTI! Share this post Link to post Share on other sites
