CCollier300571
Rear Axle
CCollier300571
No problem buddy. You can either do it via PM, or if you prefer I can give you my mobile number so we can talk on the phone.
Tom
Sent you my number taa
CCollier300571
Thinking about it. If you dont know the history of the beam. The cars are well old now and because of how they are engineered. If you intend keeping the motor and having it as close to mint as possible then its probably best to have a complete rebuild, then if you get a quality job done then it should last the life of the car.
.......................... if you get a quality job done then it should last the life of the car.
no chance, it needs to be serviced periodically.
SurGie
That does depend on what type of bushes you fit, if you re-grease the bearings every year or so im sure it would last a good amount of time.
Cameron
Mine's lasted 5 years so far without any maintenance, I've had the arms off a few times swapping various bits around and inspected it but it's never required any work.
Argument waiver - the above is an observation of my own beam and does not apply to all - yours may be f***ed.
I recommend a strip check and re grease every 3 years.
d7ve_b
Is that what you say to all the girls? Lol...
SurGie
I dont think girls have anything to do with it :ph34r:
Humour failure alert!!
CCollier300571
What sort of gap between the tyre and the inner arch should the norm be?
harryskid
Rear axle , wheres the front one then ? :lol:
PhilNW
Just stripping a rear beam in a RR car but it originally came from my previous stage prepared car. Loads of grit and grease but it needs new shafts, bearings and seals.(which I have just collected from Peugeot dealer) One shaft is flush with the arm the other appears to be recessed and been welded (presumably to prevent it twisting?) Any ideas which one is correct and why are they different?
Edited by PhilNW
both should be recessed 2mm
PhilNW
Thanks Welshpug
