dave205 19 Posted December 19, 2011 Just a quick question, whats the difference between 1.6 gti and 1.8 n/a diesel struts if any? Share this post Link to post Share on other sites
welshpug 1,646 Posted December 19, 2011 no droplink tab on the base model type struts, plus damper length and damping rate. Share this post Link to post Share on other sites
dave205 19 Posted December 19, 2011 I assume the difference between diesel and turbo diesel struts are different then aswell, considering diesels use tu subframes and arms and turbo diesels use the same setup as a 1.6 gti? Share this post Link to post Share on other sites
pug_ham 243 3 Cars Posted December 20, 2011 That depends on the turbo diesel model you have because the STDT turbo diesel should have the GTI front suspension set up which should be fitted to the majority of the TD 205 but from experience it isn't always that way & some have the base model arb / wishbone & strut arrangement. Only way to know what it has is to look at the car in question, if it has the GTI set up you can see the bottom of the droplink from in front of the car if you look underneath. g Share this post Link to post Share on other sites
