Biggles
Alternative Oil Pressure Sensor
Biggles
Does anyone know of a 1/8 NPT oil pressure sensor that works with the standard 205 gauge ? Either of the Smiths ones (Classic or Cobra) for example ?
Something 0-8 bar rated should be fairly close - probably won't be spot on, but lets be honest the standard gauge is only a relative indicator at the best of times.
Many aftermarket senders are 0-5 or 0-10 bar rated and would thus read quite differently to the standard sender, so check carefully.
brumster
I would have thought not only would the pressure range need to be the same, but the resistances at 0 and 8 bar would need to be roughly identical too.
