Artemide
Abs Not Working
Artemide
Hi,
I have 3 1.9 Gti´s with ABS, and it isn´t working on none of them. And as far as I know, no ones ABS isn´t working and never has( at least here in Estonia where there are only about 10 GTIs max). Soo, has anyone sorted out what could be the reason. One minute after switching on the ignition, the abs bump makes a sound for about 1 second and thats it. The abs warning light stays on forever. Also have tried switching the pump.
tried new sensors? sounds like the relay is ok if the pump whirrs,
Para
Lots of things might be faulty, you should check the wiring going to the ABS sensors in front hubs, also there is a way of reseting the ABS system. I'm not sure how to do this ? Unplug for couple of minutes plug from ABS ecu in the boot.
You should do diagnostics.
