cir287
Patch Rust Holes In Floor
cir287
Hi, been away from here for a while but am back on the case again.
My '86 205 was lying up for a few years with a wet floor. It now has a few holes where the rust has penetrated from inside to out. I'll probably sand blast locally prior to cutting the hole a little bigger to get some reasonable metal thickness and then weld the patch on the underside (outside) of the floor followed by welding around the hole on the inside.
I have some flat sheet from a van I cut windows into which I plan to use for the patches.
Does this sound about right ?
harryskid
Sounds good but make sure your new metal is the same thickness and if its from and old panel make sure its clean be for welding !
