feb
Rubber Boot/cover Behind Headlights With Hids
feb
How have you guys with HIDs fitted the rubber boot/cover behind the headlights?
Does it fit or have you cut it/modified it?
I am thinking of getting a set but I want to make sure the rubber cover will fit before ordering them.
Thanks.
BlueBolt
Doesn't the rubber cover have a kind of drain lip at the bottom for the wires to come out through?? I've done mine but can't remember what I did lol
When you get yours, make sure u get the 1's that give you HID on full beam as well as driving lights!!! I got ones second hand off feebay and the full beam light is a second bulb, which gives very yellow light after my 8000k lights gave been on... End result is that I don't ever turn full beam on...
Mate with a Clio Williams has his full beams on HID also and when they come on they light up theist part of Kent
Edited by BlueBolt
feb
Could you take a picture from the car what the beam pattern looks like?
I have been reading that they scatter the light and the beam pattern is crap so I may be better off with some higher intensity bulbs/Osram night breakers.
I am aware that they scatter the light as I have seen in my dad's Panda and Focus but they are not too bad in these cars.
I am wondering if it is much worse in the 205 before throwing money away.
Edited by feb
BlueBolt
Car is currently off road and no battery life, sorry mate would have otherwise
Ive never had a problem wiv the way te lights sit tho...
