ash mi16
Gearbox Help
ash mi16
hey, ive got a mi16 engine in my ph2 205 1.6 gti its running piper cams ported and polished head and twin 40 weber carbs, i just want to no wot would be the best box to use, ive been told that the be3 1.6 gti box would be good but i use the car every day so would like to no wot would be the best box as i want excelleration but dont want it to top out really quick, thanks ash
Everyone has slightly different preferences and there's no "right" answer as such, but generally speaking, I would say that either a 205 1.6 GTi gearbox or a 405 1.9 Mi16 (or 306 S16 and Xsara VTS - very similar ratios) are the best compromise for a daily driven 205 Mi16 in terms of acceleration, cruising revs/noise and, for what it's worth, top speed*
It's been discussed at length many times before, so if you do a search you'll find lots of posts on the subject, and the exact gearing / differences between the various gearbox choices.
* - less of an consideration in my opinion, seeing as just about any gearbox will easily pull well into license losing speeds in this country.
ash mi16
thanks mate, im using a 1.9mi16 box and its ok :)
I'd stick with that then - certainly little point of going to the effort swapping that for a 1.6 GTi if there's nothing wrong with it IMO.
Roughly speaking, a 1.6 GTi 'box has closer spaced ratios than a 1.9 Mi16, with a shorter 4th and 5th meaning higher cruising revs for the same speed - it's approximately 5% shorter geared in 5th, so around 200rpm difference at 80mph.
ash mi16
ok thanks mate il probs just stick with the box i have :)
