stu8v
Torsion Bars
allanallen
Yes they're good. Hardcore track car running slicks and negative camber will require 25mm + bars IMO
Hasn't this been on here before? I think the question was asked about the material used and a answer was never really given, I;d ask who has tested them as well
I've got some 23's in my ZX road car, believe they came form them via a group buy on the Rallye Register.
Quality of the machining and finish is great, can't answer whether they have been heat treated properly though.
allanallen
Does anyone know the exact material and treatment process that original pugsport bars went through??
These bars may not be the same as originals but they work well,don't sag etc so who cares!
stu8v
Its more a case of snapping I'm worried about.
allanallen
Good luck snapping one :D
I doubt you'll ever find that out. I know that if they aren't made from something like EN25/EN26 and hardened and tempered, they'll just sag, going rock hard, because they've been extended past their elastic limit and probably snap. The resultant mechanical properties need have a UTS of >1000MPa and hardness 40 Rc. Member 309PUG on here makes a very nice product and I now buy through him rather than getting them made locally in Sydney. The ebay site above may well be his. Not sure. If the bars are still "bright" in appearance they haven't been hardened/tempered.
SurGie
Ask them if the ones they are selling have a reading of 40 'Rockwell C' hardness, any less then you might as well chuck them away. Also ask them if the the material is made from EN47, which is the ideal type for torsion bars.
Cameron
Don't give the guy the answers! Just ask what material they're made from, what heat treatment they've had and what their hardness is. If he knows his product those should be easy answers, giving him the values in your question just makes it easy for him if he doesn't.
engine killer
Will adding a Whiteline one be better if it is additionally added to the system? At least it has adjustability.
Cameron
That's an anti roll bar though, so will do nothing for the spring rates.
engine killer
oh, i misread torsion bar as antiroll bar :blink: sorry
spikster
Ask Anthony on here to supply them.
Getting mine from him, 24mm Torsion bars and 25mm ARB.
He has supplied quite a few of these.
Andy
allanallen
Andy
As far as im aware Anthony and pauls(205turbo) bars are supplied by the guy on eBay.
SurGie
Yeah sorry, i should have re-phrased that part of it.
stu8v
Mmmm you've not seen me drive!!! ;)
This!
I have plenty of these and have had for years, they're ace! Thousands have been made over the years, never an issue.
Edited by Baz
Powers
What's the guys username on eBay?
