Josh_Quant
Mi16 Cams Help!
Josh_Quant
Hi fella's need your help like normal :lol:
Iv got a 1.9 mi16 catcams inlet cam and wanted to fit it to 2.0 mi16 but came aross bit of a problem i think that they not changable!
my 2.0 cam has got a lobe for the camshaft sensor and a slot to run the vaccum pump on the oppsite end of the cam and the 1.9 is just plain.
here a few pics of it hope you can see it ok.
Josh_Quant
Josh_Quant
cheers mate!
I will be looking for someone with a milling machine now :D
Josh_Quant
would you be interested in doing this for me peter t?
which ecu are you using? as you're going 2148cc I guess not the standard one, if so then just leave that off.
Edited by welshpug
Josh_Quant
on standard with superchip limiter (6900), uprated fuel pressure regulator, gti6 inlet manifold
why not the standard one? i cant afford £1500 to buy ITB and wont be running twin carbs becuase i want to get more than 20 MPG :lol:
I know it wont be using the bottom end to it full potential
so i need it to run cam sensor and my vaccum pump
Edited by Josh_Quant
oh dear, that's just a big failboat waiting to set sail :(
You need to have a think about this, GTi6 injectors don;t run on a std ECU, the S16 ones will be wrong for the engine size and power, Even on a std engine the 6 manifold confuses the S16 ECU
If you cannot afford the rest then I'd leave it for a while
Josh_Quant
will be running s16 fuel rail and injectors. and i havnt got a standard bottom end mine was worn :unsure:
iv been driving well over a year with gti6 inlet manifold been running fine had no problems??
I really appriate your opinion
couldnt i run slightly bigger injectors still? for the extra cc
thanks Josh
you can't just stick larger injectors in as the ecu doesn't know that you have done so.
Mattsav
You'll have to grind through the hardened layer before you youve got any chance of milling the Catcams inlet. They are STeel billets as opposed to the std chill cast cams.
