Fox
Does This Look Like A 309 Beam?
Fox
Bars are 20mm, just strange it has the fuel tank bracket?
jord294
if it is a 309 beam, perhaps someone decided to fit it to a 205 and use the brace aswell
20mm bars are a good sign that it could be 309
measure the length as i can tell you for definate then
SurGie
Yes thats a 309 beam, check the ARB too. The colors of the red torsion bars is the same as my old 309 beam with the yellow stripes the same colour as yours, The mounting points are not offset, the bolts are in the middle of it compared to the 1.9 that are clearly offset.
Width VV
Fox
Cheers chaps!
