stuart1298
2.0 8V Turbo Dyno Results
stuart1298
Right, after last months dyno of 97bhp I tracked down I had a missing nox sensor, So took it down there today, and hit 164.8 so little bit of an improvement ;) but its still over fuelling, air filter is getting plenty of air, new nox sensor, which Is working, genuine pug temp sensor, but I hit boost at 4250 rpm my air to fuel ratio drops to 10.5:1 (which is as low as it measures) and power drops to 150 bhp
so what did it make today? the standard 150 or 164?
Am I reading right that it doesn't make boost till 4250rpm?
stuart1298
sorry, i maybe reading it wrong, i will upload the results
stuart1298
should mean more to you guys
Any plot of the torque?
But if it's a std engine, Power is kept well as they don;t normally as it's all out of puff by 6000
stuart1298
thats the fueling and bhp sheet, the torque is on another print out, but battery has died on my phone, so cant upload the other pics now,
the only mods to the engine are exhaust system, induction kit and front mount intercooler, nothing else has been up rated
My memory is a bit hazy, but isn't the rev limit on a 2.0 Turbo engine well before 7000rpm as suggested by that printout?
If the RR isn't measuring rpm properly then that throws any figures out of the window, given that rpm is an integral part of the power-torque calculation.
dcc
dont they assume youre running with as close to a 1:1 gear ratio to estimate rpm? so depends on what gear your in ? also thats running very rich. what ecu is it? what injectors?
and what fuel pressure
stuart1298
They were running it in 3rd. Standard ECU, injectors and pressure regulator, might get a new regulator in it if I can't find some one with a tool to messaure it
sounds of silence
looks more like a management fault like a cts or such like and went into a default and just over fueling , but again the rpm on the graph doesnt look correct
stuart1298
Just had a genuine cts fitted, so should be ok
sounds of silence
Was only using the cts as am example mate i would be looking for a sensor fault tho
stuart1298
And idea what other sensors. It's had brand new, crank, lambda, nox, ect sensors
so what's actually wrong?
wicked
Don't drive at max with this afr; you'll get bore wash and your piston rings will wear out fast and polish the 'liner'.
With how much boost do you (intend to) drive?
I expect a failing fuel pressure regulator; normally you can check it if you take off the return fuel line and see if it returns fuel to the tank, but would not advise to do that on a RR with hot engine.
ross009
post edited for being completely in accurate due to me not paying attention
Edited by ross009
stuart1298
I'm running .8 bar will get a fuel pressure tegulator
Your not rich your lean very lean!! at max power 164 bhp which you hit at 4250 rpm your afr is 15:1 this is WAY to high even then when you drop off the power your afr's are still way to high at WOT at full boost you want to be seeing in the high 12's on afr iw ould say your not getting enough fuel pressure or injector problem?
What graph are you looking at?
The one I'm looking at shows afr at 13:1 to 12.5:1 which is ideal, until it then plummets to 10:1 which is too rich.
Not sure where you have got 15:1 from?
ross009
ha ha ive read that like a retard completely ignore my post sorry!
stuart1298
I was wondering of the pipe that comes from the throttle valve to the pressure regulator might be blowing the regulator shut at high boost rather than allowing it to open, I no its working fine at low boost as you can see it doesn't over fuel till boost kicks in, I'm new to turbo'd cars, this is
My first, so all a learning experience to me
ross009
i think it should have a one way valve in it mate my only experience 1st hand is renault 5 turbos but a vacum line to the fpr will go + pressure and could defo do weird stuff
there's no additional valve for the FPR, when when it sees vacuum it'll drop the pressure, I don't think it will raise it past 3 bar at all but possible it is.
easy t check, hook up a pressure gauge, must be for Injection as a carb gauge will not last due to the pressure.
stuart1298
Just seems strange it's only when the car hits boost
