rsta1466
Facet Fuel Pump Problem
rsta1466
hello
i have recently converted my 1.6 gti to run on r1 carbs, the parts i used and the way i have it set up is, facet fuel pump mounted where the old fuel filter was, then into a filterking regulator and then into the bronze fitting ont the bottom of the carbs,
the problem i am getting is that when the pipe coming off the regulator is connected to the carbs the pump doesnt seem to work, i just clicks and no fuel seems to get to the carbs (im saying this as i have the guage on the filteking and it just flutters around at the bottom), however if i dissconnect this pipe and put it into an open container the pump pumps a constant stream of petrol and still clicks a little bit but is much quieter.
is there a problem with my pump? or have i done something stupid anywhere else?
thnaks Rob
christophe
Is there a return to the tank? It seems like it's trying to pressurise and unable to get rid of the air in the fuel rail.
TT205
Is it a red top?
I killed two before it was pointed out to me that they shouldn't be mounted horizonatally, I couldn't mount it vertically so had a bracket made so it was as upright as poss - no probs since
