RummyonFire
205 Electric Sliding Sunroof
RummyonFire
Hi all
This is my first topic hope you can help
Ive just bought a Dimma which has a sliding sunroof
The guy i bought it off stripped the inside which isnt too much of an issue as i have a donor MI16
The sunroof has the mechanism but not the actual winder to open and close it
Ive tried everywhere to get one but with no luck
As an alternative if i cant find one i was wondering if it would be possible to get an electic motor from another peugeot/car if so whats the best to go for and how would it be done?
cheers!
trogboy
If it is a standard factory fit sunroof (slide only type jobby) then there is no mechanism to slide it: just a handle which attaches to the glass to pull back and forth. The only mechanism is the handle which deflates the seal and pulls in the locking pins so that you can slide the glass.
RummyonFire
Its a Britax sunroof and definatly has the winder mechanism to open and close it. just been out with the torch to check lol
allye
Britax were the dealer fitted ones so not many about.
Henry Yorke
Pop a pic up so we can have a look. I am sure Britax will have made a power version and I have seen them in 205s historically.
yes they did, not just a dealer fit as most windscreen companies fitted them too, No spares thou at all, My mate tried a while back
eddie bullit
I had a J reg 106 xsi with an electric sliding sunroof. The guy I bought it off had it from new and worked in the parts dept. at Peugeot Manchester. Probably the same thing eh?
RummyonFire
Hi thanks all for the replys
been working and just managed to get some pics
I have found a company that can replace the winding unit but will cost £55 which i think is extreme for the little part i need
heres the pics
chipstick
I think mine may be a Britax one that people speak of.
It is a large glass sliding unit, but doesn't have a vacuum. It doesn't leak at all, so I am not sure if these are 'better' to have than the vacuum ones?
RummyonFire
Yeah thats the one its a non vacuum as far as i can tell.
Ive managed to find one whilst searching the net, i wasnt sure whether i could use a handle from a different sunroof dependant on how the handles actually clip onto the unit.
i know they are rare and finding parts for one is nigh on impossible
As mentioned above ive managed to track one down, its cost £55 but its the full unit with the shroud soi guess if the one i have breaks i have a backup lol
thanks for all your help guys
