stuart1298
Retro Fitting Obd To Xu10J2Te In 205
stuart1298
Managed to find the pin out put for the connector, but cant seem to find a decent diagram for a 406 loom, i need to identify what wire on the cars looms would be can-high J-2284 and the can low, can anyone help, i remmeber some had some loom diagrams on there sigi, but cant remember who, i have found a few diagrams, but none are clear as to what wires i connected to the OBD port
as far as I can remember it'll be the same wire numbers as on a 306 which is all I can find at the moment which wold be ;
pin 3 is wire 426, pin 7 wire 140, pin 15 wire 141
stuart1298
I've got a screen shot i took on my phone of a forum post, with some wiring from a gti6 so that may help, just gotta work out which way round they wire up, looks like a job of make a fault... Wire the power wires up, and see what I have to connect until I have a fault come up
jonnyturbo
i have a 2 pin plug for my obd but when plugged in nothing was comming up on his screen, if i can il find out what pins my plug goes to as maybe someone could verify if its right or not but when i rang pug1off and told them it didnt work when plugged in they said the wires in the back of the plug could be wrong way round as there was no way to tell which went to which?
Josh_Quant
for my 205 2.0 mi16 i have a green 2 pin plug on my engine loom thats my diagnostics plug if that helps?
and i gotta use 2 pin plug with snap on modus and plug a wire into fag lighter for power
