dave205
Lamba Sensor Position On Turbo Conversion
dave205
Before i start i did try a search!!
Im ready to fit the lamba sensor on my turbo conversion, how far down the downpipe should it be in inches??
12" or so will suffice, what us more important is the orientation so that anycondensation will not sit on the probe.
dave205
How should i orientate it so this wont happen?
dave205
any one?
think logically....
or look at a standard cat off a pug, typically they are horizontal and angled forwards for clearance to the exhaust tunnel
dave205
think logically....
Should it be slightly more than horizontal to prevent condensation sitting on it as tom said? and when you say angled forward how'd you mean??
dave205
think logically....
dave205
think logically....
Mark Greenwood
anywhere between 3 o clock and 9 o clock is ok,, but between 2 o clock and 10 o clock is optimal..
and as Tom said " 12" or so will suffice, "
Edited by Mark Greenwood
dave205
I assume you mean anywere between 3 to 9 oclock as 3,4,5,6,7,8 or 9 oclock positions, not the topside of the pipe?
Mark Greenwood
my bad,, that was a terrible desciption... sorry mate
it needs to be as close to 12 o clock as you can get it, ideal at top, but anything as low as 3-9,, nothing below that.. so not 4 5 6 7 8 as condensed acidic water and oxides will pool here...
dave205
Ah i get u know! :)
I cant fit it at 12 oclock because of the tunnel, so im either going to put it at 10/11 oclock or put it closer than 12" to the manifold.
