jonb_5
C5 Steel Wheels
jonb_5
Hi
You may have seen this, but I think these are the lightweight wheels you can change to which are a direct replacement. Can someone confirm this? Maybe of interest to some members, not mine just found when looking on ebay.
http://www.ebay.co.uk/itm/16-Citroen-C4-coupe-C5-Break-4x108-et26-winter-steel-wheels-Brand-New-Set-4-/160655757264?pt=UK_CarParts_Acc_Wheels_tyres_Trims_Car_Rims_ET&hash=item2567d44fd0#ht_1755wt_908
Jon
erm, no :lol:
guess you didnt read the title properly, they are 16", also the wrong offset being ET26 as well (though at 6.5" wide the offset isnt actually too far off, they will fit most cars dependent on ytres used)
must admit they do look right, but thats just a catalogue picture not one of the actual item
kyepan
agreed, ask him to read the serial number and search for gentrix's old post that details the correct ones.
my search term
c5 wheel -arch -nut -nuts -bolt -steering
this is not a correct one, because the bolt seats are flat (like gti) and not tapered
note the difference to this one, where the bolt seats look tapered, instead of flat
Edited by kyepan
There are two versions of the C5 wheels, those with flat seats and those with tapered seats. The flat seat wheels were released first and then recalled due to possible cracking problems. I wouldn't let this concern you however, as a friend of mine races on these without issues, but the possibility is always there.
SurGie
Agreed, the flat ones are weaker and the tapered ones are the stronger version of C5 alloy's. I nearly bought some flat ones and glad i didn't now after researching them.
Getting the correct type of tapered bolts/nuts are not hard to find if you know where to look.
