stuart1298
Help With What Sensors What..
stuart1298
this is the coolant housing on the end of the head, i need to work out which one is the coolant temp sensor that controls the fuel,
i have got new injectors seals, fuel pressure regulator,
green one
Rather than spamming the forum with constant new posts, why not start off one about the issues you have and then keep it going, so there is some detail and history. Instead of starting 2 new posts a day.
stuart1298
cos i dont no what all the issues are, i'm finding one, solving that, then highlights another problem, so and i have a neighbour who can do bits and pieces while i'm at work
Read what I wrote. By adding on to an existing thread you will find people are also more inclined to help. Rather than just bombarding us with posts with half the info missing.
stuart1298
right, see what ya mean :(
had bit more off a look, seems i may have the wrong coolant sensor, managed to find a brand new genuine one, so got that on order, there is a little valve that goes in the middle of the pipe that goes from the oil filler housing to the throttle housing, the arrow on it points to the throttle so assuming this is a one way valve, i have got another valve, not the same one tho, as its b/o with dealer, anyone no what it could be, pic below
