omri617
Valve Settings? Dkz Engine.
omri617
Hope i'm using the rught phrase :
Can anyone please tell me what are the correct settings/numbers of setting the valves on DKZ engine?
I will be using Filler Gauge with inches/m"m also
thanks a lot
.20 mm inlet and .40 exhaust :)
omri617
thank you very much!
by the way is this the reason i feel the car more powerful and faster at first 5 minutes of driving in the morning?
DaBull1981
Don't push your car to much when cold
omri617
O.K , may i ask why?
thanks
DamirGTI
Needs to be warmed up to the operating temp. , engine temp. @ around 85C , oil temp. @ around 70C (70C minimum ! 90-100C best) ... before that , keep your foot off the speed and revs above 3000 .. if not you'll f*** up the engine (cold oil + high revs/speed is dangerous stuff .. don't do that ...)
Treat it like a human being , fancy doing a fast running marathon in your pyjama when someone suddenly woke you up from the bead in the cold morning when you barely able to open your eyes let alone running ? .. course not , you slowly wake yourself , stretch up , dress up , toilette freshening up , cup of tea/coffee light breakfast , few hob nobs and off you go .
Damir B)
