enduro
Pas Into Base Model
enduro
can a pas rack be fitted into the base model / tu cars, or is there simply not room for it, fouling on the downpipe perhaps?
Fouls on the gear linkage from memory - if you do a search for posts by Adam_P you should find pictures of the issues when he tried to fit a PAS rack.
enduro
would that still be the case though with the ram removed which is how i intended?
stuart1298
Surely if you remove the ram. You lose the power steering?
Jrod
If you are doing it for a quicker rack then it fits fine as I did it - hated it though as there was too much play in the PAS rack IMO.
Paul_13
A base model diesel manages it, pas pump on the gearbox though. Hang on BE gearbox not Ma
GeorgeXS
Nope doesnt fit. Gear linkage fouls the rack even with the ram removed.
Jrod
This is very strange as I did this on my old rallye. I'm just wondering if I was using the modified GTI subframe at that time and if it would make any diff but I don't think so!
JackTar
What about fitting a PAS rack to a CTi subframe, because they're the same as a CJ aren't they? So won't the rack still foul the gear linkages?
BE4r gearbox conversion?
This!! :D
looking through servicebox no MA boxed 205 or 309 ever had PAS, it was all the XU engines which kinda makes sense as they are heavier and had wider tyres.
jonb_5
Sorry to hi-jack the thread but if power steering doesn't fit can you fit a quicker rack to it, i.e. different size cogs to make turning quicker?
Jon
yes, quaife do a quick rack
