MiniGibbo
[misc_work] Minigibbo's '93 Peugeot 205 Rallye.
MiniGibbo
Sorry for the stupidly..
But what from where..?
MiniGibbo
Found the site and what I think would be the correct plug for couple of quid... add postage and its £7..... think ill stick to my idea of cutting one off a scrapper with some length and just crimping a second hand plug on :/
Zacky-94
Cut a plug off a scrapper with about 4 inches of wire leaft on it and get you're self abit of heat shrink solder the plug onto you're loom for a permenent fix , don't bother crimping it it will cause you hastle in the future , plus they look un tidy
MiniGibbo
That's the aim. The wires won't take the solder though.. Even trying to tin them first :/
You'll need to crimp them, the wire corrodes and this is another issue with the older looms now as well
... or cut back the loom far enough to give some uncorroded wire if you want to solder - be warned though, this can be 12" or more in some cases!
MiniGibbo
It's mad how much they deteriorate... Haven't ever noticed it on other cars of similar age, only the peugeots :/
You think that's bad - from what I can see, that 106 loom has the later sealed connectors that are generally much better at resisting moisture and corrosion related issues compared to the woeful unsealed connectors used on 80's and early 90's era PSA cars (like 205's).
Have a look at the original 205 connectors still in the engine bay (eg the earth plugs between the radiator and headlights) and you'll see what I mean - chances are that the pins will be green with corrosion and the wiring brittle as anything. There is a special place in hell reserved for whichever bean counter insisted on that cost cutting measure given the resulting electrical woe it resulted in years down the line <_<
MiniGibbo
Yeah.. I haven't given those connectors much attention near the headlights but Miles has haha
Think he's done the indicator and horn so far.. That's after giving the loom a good going over in the first place.
205's are defiantly adventures haha
MiniGibbo
Plug fitted and it now sounds right to my untrained ear.. Sounds just like the old engine and the idle is steady on the dials
MiniGibbo
MiniGibbo
Gearbox oil filled (surprisingly easy job actually) and final checks done.
It may idle fine but still isn't a happy boy when driven, I took it around the block and it misses like a proper little bugger :/
S1 1400 XSI ecu is soon to be brought to try.
MiniGibbo
I also have no speedo even though the cables pushed in with the rubber pin and the white plug is on :(
MiniGibbo
Speedos now working again :)
Going to try new leads today then if that doesn't help another coil pack.
MiniGibbo
Didn't bother with leads in the end as I checked the leads pre plugs are they're sparking fine.
Started looking for air leaks. Reseated the injectors and its better unload now but still missing..
Wondering if its the inlet it's self but that's an arse of a job so want to try everything else first really.....
MiniGibbo
Cars sat idle for a while now as I got bored going round and round in circles trying to solve the missfires so I dropped it off with Pugracing nearly two weeks ago now and got the result today...
80% leak on two inlet vales, being a 8v there's not much point fixing it as it would mean all new gaskets again.... So a new engine it is, this time built/fitted by someone who knows what they're doing :(
Watch this space.
Lowercase
whats the latest matt? and how did you fix your speedo by the way?
MiniGibbo
With pug racing to be fixed...
I fiddled with the speedo cable on the gearbox end and it started to work, think they need to locate properly to work 100%
MiniGibbo
Its certainly been a while since I last posted about the car, after the trouble I had with the refreshed 8v me and Miles of Pugracing came to the conclusion the only way forward was to fit a tu5j4 out of a 106 gti.
It wasn't trouble free, I had to buy a couple of engines as I managed to buy what can only be described as a scrap engine advertised as as 'like new with many new components.. once I bought a good engine though the work began.. this not being a straight swop needed work but nothing Pug Racing couldn't handle. few bumps along the journey but im glad we done the conversion as its transformed the car.
the spec of the car now is
1600 16v single plug TU5j4
TU5JP4 rocker covers
S1 106 Rallye gearbox
BBM group N engine mounts
BBM group N gearbox mounts
BBM group A lower fork bush
Custom Ashley 421 exhaust manifold
Cold air ram and Induction cone
Straight through Race centre tube
OMP Group N backbox
Pug Racing gear linkages
The car aside from the engine needed three new wheel bearings and gear linkages, then was realigned. It drives completely different now, ive only done around 40 miles in the car so far but I cant feel the extra weight over the wheels from the 16v people say about.. all in all.. money defiantly well spent :)
Looks tidy, but you need to update your sig again now :P
MiniGibbo
Thanks, done it :)
Reebmit
Hi Matt, chatted to you at Miles the other day, discussing bonnet etc..... good to see you have it running, looks great :)
allye
Looks fantastic, I'm sure miles did a great job.
MiniGibbo
@reebmit, yeah I remember :)
Yeah it's a completely different car now :) it was good before but it's been transformed
