[Car_Overhaul] Laser Green 205 1.6 Gti
Alan77
Great work! I love these rebuilds from scratch...
Daviewonder
Tom, any idea what that hole is for in the metal strip that goes between the caliper sliders and the bolts?
No, it doesn't seem to be used for anything on the 205. Perhaps it's a parts bin special originally used on something else where that hole has a purpose in life?!
Slo
Love threads like this superb detail Tom, hardcore 205 porn is rare these days (who wants to see pictures of someone changing a wheel/headlight if you know what I mean).
I think that hole is to hold the brake pad wear sensor wires originally with a fastener?
eddie bullit
Looks really amazing Tom. I can't wait to see it finished. A real inspiration to get mine started.
Only one picture today, the front subframe built up with new wishbones, rebuilt steering rack, rebushed fork, anti roll bar etc
35565759494_97257a9935_z.jpgUntitled by Tom Fenton, on Flickr
allanallen
Looks nice gaffer! Thought you were outing PAS on?
Not on this one mate, I'm keeping this as it was. PAS stuff is for the blue one when it goes back to 1900 8v.
hoodygoodwood
Great job , you will be scared to drive it by the time its finished .These cars deserve a bit of TLC .
So update today.
Rear end is as far as I can get for now, so turned my attention to the front.
First off removed the front legs and front subframe/steering rack/shafts
Next on the agenda removed the master cylinder, it was working ok but looked crusty, and I've heard enough horror stories of 205's hitting things due to failed master cylinders!
36264102561_a59ee8549e_z.jpgUntitled by Tom Fenton, on Flickr
Now i thought I'd finished with scraping underseal but oh no some more awaits. Grot grotty grot.
36264102291_8cb76244ab_z.jpgUntitled by Tom Fenton, on Flickr
In progress
35593177193_ba09c5dd83_z.jpgUntitled by Tom Fenton, on Flickr
Ready for final prep and paint
36004181910_f5afdd73d5_z.jpgUntitled by Tom Fenton, on Flickr
dcc
Tom please can you stop posting photos, it really bugs me.
What I mean is mine will never ever look that good, in fact I actually doubt it looked anywhere near as good as that when it came new from the factory, so if you don't mind.
Or at least just use black and white photos from now on. Cheers.
In other news, seriously sweet looking motor :)
Alastairh
Looks great Tom, nice work.
I wasn't in the mood for underseal scraping tonight so instead set about repairing the gear linkage rod heatshield.
It had the usual corrosion damage around one of the mounting studs, I'd taken it to work and wafted it over in the shotblaster, I didn't want to go too mad as it's only ally and the blaster could make holes in it.
36232961142_38dc8ac205_z.jpgUntitled by Tom Fenton, on Flickr
So I made a repair piece then welded it into place
36356314986_62e66f1fbd_z.jpgUntitled by Tom Fenton, on Flickr
Then I painted it, made a replacement for the small bracket at the back, and riveted it on. Pleased with how it's turned out really.
36232960872_66c02962ba_z.jpgUntitled by Tom Fenton, on Flickr
When I was under the car I noticed the rear mount bush was looking a bit soft and soggy so I dug a better one in a housing out of stock, sandblasted the casing to clean it up then went over with some lacquer to stop it furring up again.
36356314426_ef015ceda0_z.jpgUntitled by Tom Fenton, on Flickr
Finally decided to test fit up my driving lamps. They are my plated and powdercoated frames, Denji glasses, into OE backing shells, with a pair of the PSCUK protectors.
36400841695_0c31c8a5bb_z.jpgUntitled by Tom Fenton, on Flickr
mrfirepro
Nice work Tom
Given me some good ideas as well, keep them coming.
Was the paint anything special you used on the heat shields, I just know I'm gonna have to copy that , they look good.
allanallen
Nice effort on the heat shield buddy! That's some thin ally!
On the heat shields I acid etch primed and then painted them with zinc cold galv spray. Will see how they last.
Welding the piece in was really s*it or bust, as you say mega thin! It went OK though, I'm pleased with the result given that no one will ever see it anyhow!
deathbringer929
ive seen him weld one of my red bull tins i split. very nice thomas
A bit more cleaning and scraping last night and this morning.
As usual got bored of that so found something else to do, which was to fit an airbox support bracket. Fitted perfectly and what a nice thing it is too even if I do say so myself!!
36356313776_4d605754a0_z.jpgUntitled by Tom Fenton, on Flickr
This afternoon got the OSF arch in stonechip then paint. NSF is also nearly there. Have to say I'll be glad to see the end of the cleaning scraping and painting phase for now! Engine bay clean up and engine and gearbox renovation I plan to do another time.
36232961392_a071a74bf6_z.jpgUntitled by Tom Fenton, on Flickr
I also decided to break out some more goodies from the stainless reproduction shelf so fitted a stainless driving lamp bracket whilst I was there.
35565758854_f8ce233451_z.jpgUntitled by Tom Fenton, on Flickr
dcc
can see this being at pug fest at this rate!
That is the goal Dan. Hoping to have it ready for MOT before the end of this month with a view to taxing it from the start of July.
Once I have finished the NSF arch I have everything else barring refinishing a set of wheels ready for it.
First off today bulkhead heat shield blasted and painted.
36400841395_7ff6098e21_z.jpgUntitled by Tom Fenton, on Flickr
Next onto some real work, NSF wheelarch. Got it finished and masked up
36264101981_c553fd524c_z.jpgUntitled by Tom Fenton, on Flickr
Then into paint (wahoo)
36400840925_b0de432bb5_z.jpgUntitled by Tom Fenton, on Flickr
So thankfully (as I've had enough of the mess now) that's all the painting done for now. Tomorrow once it's all hardened off I can start getting the subframe and suspension back onto the car.
No pictures just now, but subframe is on, legs are on, steering rack connected, brake pipes 90% done, new master cylinder fitted, gear linkages in progress.
MOT time is now looming!
To do list at present is;
Finish brake pipes
Bleed brakes
Driveshaft seals, driveshafts fit
Gearbox drain plug new washer
Gearbox oil
New sump plug new washer
Engine oil and filter
Refit mud flaps
Spanner check all round
Wheels to paint
Tyres have fitted
Rear valance to fit
Rear fog reverse lights to fit
Bulbs for driving lights
Tracking
Plugs dizzy cap rotor arm
So a few pics
36356313926_67bc8d9919_z.jpgUntitled by Tom Fenton, on Flickr
36356314056_b6bc03d62a_z.jpgUntitled by Tom Fenton, on Flickr
35565758944_5e33f2d4be_z.jpgUntitled by Tom Fenton, on Flickr
35565759024_d1daa442c5_z.jpgUntitled by Tom Fenton, on Flickr
36264102591_f708843261_z.jpgUntitled by Tom Fenton, on Flickr
It is also now crunch time- on my way home today I passed the MOT place I used, and in a fit of keenness booked a test for 4:30pm tomorrow... I think the phrase is again "s*it or bust"?!
Fast forward to now (forum down about 12hrs!) and she is ready for her MOT.
Last night was a long night sorting out odds and ends. One thing that tripped me up was one of my rebuild front calipers had a leak from the flexi hose to caliper joint that I just couldn't arrest. So I ended up doing a quick rebuild of one of the old calipers that came off the car. A shame as the one that leaked had been sandblasted etc and looked like new, this one has had to make do with a quick wire brush and a strip and check of the seals. I'll have to revisit this another time.
Other than that, I painted a rough rear valance with a bit of green I had kicking about, just to put it through the test. The actual one for the car is away with Paul who is sorting getting it painted properly.
Bleeding the brakes was a bit of a faff but got there in the end, the brakes are still pretty mediocre at the moment but given everything is brand new I'm sure with a bit of bedding in they will improve.
The only thing left to do is get the proper wheels for it powdercoated or painted and have the new tyres fitted. However the old stuff is good enough for MOT so will do for today.
So a few pics
36400841075_81d6223164_z.jpgUntitled by Tom Fenton, on Flickr
Suspension and brakes complete
36264102171_e03b927b83_z.jpgUntitled by Tom Fenton, on Flickr
Driving lights fitted
36400841565_0434475648_z.jpgUntitled by Tom Fenton, on Flickr
Temporary rear valance fitted
36264102441_fa0fcf2cc3_z.jpgUntitled by Tom Fenton, on Flickr
First time out in daylight as a complete car for a long time!
35593177443_09177c1093_z.jpgUntitled by Tom Fenton, on Flickr]
Quick wash ready for MOT!
