Will Eastman
Need To Get This Coolant Pipe
Will Eastman
Basically this pipe is leaking but Peugeot say they no longer sell it, how can i get hold of one, has someone on here got one or could i use some other pipe/part thanks
The pipe is the one at the top with the red arrow pointing to it
Someone will possibly have a used one (I possibly do) but otherwise Stew Baker @ BakerBM sells silicon replacements for quite reasonable money, both as a complete kit and as individual hoses as required.
(also, it doesn't go to the SAD as stated in that diagram, but to the coolant block with the ECU temp sensor immediately above it!!!)
Stew at BBM do them in a few colours :)
chipstick
I will have one of these. Well, I have a pile of redundant pipes from my old 205 engine, so have no idea which one id pick out as they are all mixed up
No, that's the SAD pipework - as I said, it's nothing to do with the SAD despite what's written on the document!
You need the coolant hoses as shown here - if you go to the bottom of the page and the picture of the individually listed hoses, you need the one in the bottom left hand corner.
johnhenry
got some of Baker BM a week ago
there is a 205 gti drivers discount of 10% available as well if that helps, really going to have to find something special to do that cheaper, even with used parts.
Will Eastman
Hi i got a the part sent to me (cheers) but its the wrong part. The pipe i need is longer and goes from the bulkhead straight to the stat housing. The pipe I have and that you are all talking about is only part of the pipe i need. I am very confused now, and added to this is the fact that the mechanic told me that i dont have a SAD?? Can this be right?
BTW still thanks to Anthony who sent me the pipe its not your fault as you just got me the part i asked for, or was told by the mechanic to ask for.
EDIT: Oh yeh here are some pics>>>>
The pipe I have taken off the car
The pipe I have to replace it
Both together
Edited by lilwille
pipe you already have is a phase 2 pipe, the one anthony sent is for a Phase 1 or 1.5. exactly as pictured in your diagram.
both cars will have the SAD but later ones were bolted directly to the thermostat housing, had the blue ecu coolant temperature sensor in the rear of the thermostat hosing, and did away with the housing said sensor was screwed into and the SAD attached top, as well as the short S shaped hose.
it looks like the BBM 205 16v pipe kits have the right phase 2 shaped hose.
Edited by welshpug
Will Eastman
Ah i see, any way of utilising the wrong part I have or do i just need to buy the different pipe?
