madspikes
Identifying Pistons...
madspikes
I have a set of pistons and I'm not sure which of the many engine that have come through my hands they have come from, and could do with some help identifying them.
I'm not sure if they came from the later lower compression 1.9 engine cat engine or the standard 1.9 engine. How can I tell the difference? I was sure i;ve read it somewhere on here but cant find.
Thanks,
Mad
DamirGTI
.. read the numbers/letters from the piston crown , and post them here and i'll should be able to help identifying them from my OE service books .
Damir B)
(photo wouldn't mind too ... just the piston crown so that we can visually roughly see the dish depth ..)
kyepan
Damir, could you possibly see if you know what mine are too, pictures in my engine thread.
linky linky
madspikes
Thanks for the replies.
Here are a couple pictures of one of the pistons in question.
The main marking is a large capital 'R' inside a circle.
Any ideas?
Mad.
DamirGTI
Any ideas?
Mad.
The R marked pistons are :
engine type : XU51C TR
engine code : B3A and B3B
Damir B)
DamirGTI
linky linky
Suppose they're been replaced , theres no letters on top of the crown ... for 16v engines it should have : A , B , C , D , ZZ , W , H , P or XX letters .
All i can see i the manufacturer code - PdC -> PDC manufacturer (they where PDC , SMM and FM OE piston manufacturers ..)
Damir
madspikes
Really?? Not sure where they came from in that case! As far I'm aware I only had 1.9 pistons!
Mad.
how long are the rods?
DamirGTI
Mad.
405 1.6 most likely ... try google -> XU51C/TR
Damir
cRaig
Sorry to hijack, but could you kind gents have a go at identifying these pistons? My mate has just bought a 1.6TurboTechnics engine, and we would like to confirm that it has the correct pistons:
On the underside of the crown it says pdc a3 and round the inside of the skirt it says 83v21++ or tt not sure
Craig
DamirGTI
Me thinks they're the TT ones ... cos , i don't have them in my book by this bottom markings .. just the manufacturer (PDC)
Do they have any letters on the top of the crown ? (but still , if they're TT ones , i will not have them listed in the OE Peugeot book , just std. ones ..)
Damir
cRaig
Thanks for the help! Is there anywhere where we can find out more info about the turbo technics pistons? Wed like to confirm their history before he carries on with the rebuild.
Craig
any marks on the crowns? or a pic. afaik tt pistons were just std ones machined a bit.
cRaig
There arent any marks on the crowns, which doesnt help
Craig
madspikes
The rods look to be 142mm (+/-1mm) centre to centre which has to make them 1.9 rods, right?
Mad
