lahondal
5 Speed Diff On 6Speed Gearbox.
lahondal
Hi all.
Someone knows if the 5speed BE diff can fit on 6speed gearbox?
I emailed to Kaaz but they dont know.
I did a research on the web and i only found a Bacci Romano´s LSD, specific for the 6speed gearbox, and it cost 1300 euro........ :angry:
Someone knows if Tran-X, ZF, Quaife, did plate-type diffs for this box?
Cheers, David.
dsont know why there would be a different one listed by bacci romano, others all fit the same.
tri_longer
  On 8/30/2011 at 12:47 PM, lahondal said:
Hi all.
Cheers, David.
As Welshpug says no reason that it wouldn't fet at all, diff housing is the same on the 6 speed, the extra gear is housed in the end.
Only thing to watch with the plat diffs like Tran-x and Gripper is they do need some of the inner casing griding away to fit properly, the quife is a strainght fit an forget, but then again is a different prospect and it does all depend on what you are using the car for.
just looked on bacci romano's site, there's no mention of a 6 speed specific diff, all their BE ones are part number DA014 :unsure:
lahondal
Really?
I must be blind.
Switching question....do you believe its worth paying the 1100+ for a Bacci Romano? Or do you think a cheaper LSD like the Tran-X or a Kaaz do the same work?
I like Kaaz LSDs, althought they are ~170 pounds more expensive than Tran-x.
Summarizing, what do you think is the best LSD in quality/price terms?
Thanks for the replies, i´m planning a large project with a 2.0 turbo engine and I need lots of information.
black lad
Tran x are an excellent LSD i would recommend them
