stuart1298
Gear Linkages
stuart1298
Hey,
I've just given my car a little test drive, wheere every thing has moved I've had to play with the linkages alot, and they've become quite worn, can I buy the little plastic caps or do can I get ones with the pins in them. The same idea as boot struts use?
Stu
harryskid
You would be best buying a set of the ones Miles on here sells. They are really good and are held in with C clips. Also check the bolt on the subframe has not come loose. Also a Bronze poivot bush is also a good buy.
nickaliath
How much are miles linkages????
nickaliath
ok.
