Carbs4me
Mi16 Full Gasket Set
Carbs4me
Just had a quote of 212 quid for a full gasket set including headbolts
is that right or can it be found cheaper else where?
If you could get them from Peugeot any more they'd be about £200 + vat from peugeot plus bolts and head gasket afaik, but you can't so not a bad price really!
Doing a full rebuild?
Carbs4me
yeah, managed to get a fully rebuilt Mi16 that had a cracked block because when they rebuilt it they forgot to put a head spacer on the head bolt. so 10miles later while at the garage the block cracked.
150 quid
Came with a spare cyclinder head
2 sets of High lift cams one for low down power the other for high end power
Super light flywheel
bog borthers inlet manifold
4-2-1 for 205 converstion
and the spacer plate to run the 205 dizzy.
also got 405 mi16 exhaust manifold
If it's been fully rebuilt ~10 miles ago you should be able to just take the complete head off the current block and put it on the new one with a new HG and bolts, rather than needing a whole replacement headset - unless of course you're dubious about the rebuild and want to redo/replace everything.
Full 1.9 Mi16 headset with headgasket is £86.15 inc VAT from AEP - click here
Headbolt set for the above from the same place is £19.96 inc VAT - click here
Carbs4me
well i was hoping to do all the crack seals etc..
Unsure of the condition of the other headgasket as i havent even stripped the engine down yet.
i was gunna reuse all the internals, just give them a check over first
