ORB
Mot Gas Test
ORB
Was just wondering what the actuall bench mark is for the figures given on the MOT sniffer to denote a healthy 1.9?
Today mine recorded:
- CO = 0.15%
- HC = 534ppm
I know these figures are very low, so was wondering if this shows I am running lean?
I know a lot of adjustment is done to get the levels down to Pass a MOT but are some figures too low?
Does that make sense?
ORB
PS - it failed, handbrake cable snapped on the rollers. Typical of it to let go then. Stupid car.
dcc
Those HC seem high? isnt that unspent fuel :(
HC's very high, Something wrong there, CO is low but is it a CAT Model? if not it should be around 2.5%
Slightly high HC's will probably be down to the cam mentioned in his signature.
So long as it starts and idles well, I wouldn't worry too much about the actual CO value - some engines seem to idle much better running lean mixtures.
pete1986
Mine had a similar HC reading. 564 I think. There is a smell of petrol when it's idling.
I think my afm is a bit worn, im going to try one my mates got to see if that improves it. What else could resolve the problem?
its a DKZ with a mild kent cam isnt it?
ORB
Sure is Welshpug!
