grantley1988
What Size Is Steering Wheel Nut?
grantley1988
Just a quick one. What size is the nut that removes the nut holding the steering wheel on? My socket set only goes to 23mm and that is too small!
I'm pretty sure it is a 23mm. Is your socket not deep enough maybe?
It's 22mm originally, but as said, you need a fairly deep socket.
Paul_13
I have to have the socket half off the extension to make mine fit. Might be your missing the washer causing that extra couple of mm on the rack to interfere.
If you have a socket set with spark plug sockets in you will find the larger one of the two fits a treat.
