stuart1298
2.0 Turbo Conversion
stuart1298
I've come to the part of intercooler pipe work, not looking forward to it...
There is a little valve on the pipe that comes out of the turbo, says on the Citroën system it's an electro valve, part number is 0382 57,
And also an idle control valve that is coming of the pipe that goes in to the throttle hosing and in to a smaller inlet above the throttle housing,
Does anyone no if I can bypass or so with out either of these or do the have to be plumbed in??
The electro valve is the boost control valve.
Why on earth would you want to try and blank these off? Plumb it all in properly and then it will work as it is supposed to.
stuart1298
I didn't no what they were, hence asking, first time I've ever got involved with a turbo car, do I replace the electro valve with the boost control thing?
No, you leave it as it should be with the connection to the ECU for now until you have it all up and running....
