bobdylan_55
Wiper Motor And Jet Wiring
bobdylan_55
anybody got any idea how theyre wired up?
the haynes diagram is confusing as anything and goes through at least 3 relays?
cheers
brumster
If my notes are correct, then at the motor end you've got :-
1 - Red - feed to motor for fast winding
2 - Black - from motor to earth
3 - Blue - constant live (allows it to park)
4 - White - feed to motor slow winding
5 - Grey - park
The washer pump is wired off pin 7 on the stalk, and this wire also feeds a pin on the wipe relay (to wipe while washing, of course).
bobdylan_55
so if i was wiring up for just one speed (cba with 2 speed) I would just connect black to earth, blue to 12v, white to switched 12v? via a relay, fuse, and stalk?, and then grey to???
cheers
brumster
I believe so, yes, although I would just check the grey (pin 5) as by the look of my notes this earths when the motor is in park (ie. when parked, pins 2 and 5 short, when in wipe pins 3 and 5 short) so it looks like it's intended to drive the relay to keep the motor going. I believe it goes to the middle pin of the wipe relay, looking at a diagram by someone else that I found off this forum and printed off - but since they're not my notes, I never verified.
bobdylan_55
Ok, so more simply lol,
12v to the slow motor speed, and ground to the stalk, should this give me a simple slow speed with no auto park? i could probably live with that seeing its not going to be used on the road very often and is purely for MOT purposes.
Thanks for your replies btw
brumster
Oh blimey yeah, if you don't want any parking or intermittent, just wire up the feed and earth to whatever switch you want :-D !!
bobdylan_55
cheers lad, much appreciated. Just got to recover from my illness now so i can get out and do it :(
bobdylan_55
cant get the bugger to work.
Had the battery straight onto the motor just to get it to turn and it wouldnt still.
i had black to neg and white to positive. Nothing?
ive tried every combination of wires and nothing.
so do i need the blue connected at all times and then the white and black aswell? or should it work with just black and white?
thanks
alexcrosse
Did anything ever come of this? Just drawing the wiper circuit into a diagram for my car at the moment and the haynes isnt really helping me, I'd like to no who thought it was a good idea to draw switches and relays as boxes with no clues as to internal workings!...
Any help would be great.
Cheers,
Al
M5 - earth
62 Live from relay.
61 Live via ignition.
200 - fusebox - 29a, stalk
31a - fusebox - 31 to stalk
33a ign live to stalk from fusebox
102, feeds washer pump, triggers relay as well.
200 and 31a from what I can figure out would be the two different speed triggers.
alexcrosse
Cheers pal. Any idea on 62? What relay and when should it be live? :S Is there an intermittent on 205's? Or just slow and 'fast'?
Also, is it a feed from the stalk or does it earth? Guessing a feed since all the original relays are external?
Edited by alexcrosse
I was looking at the 405 manual, as most psa wiper motors are the same.
http://www.buzzboxx.co.uk/Haynes_405.pdf
page 277, looks like they are lives, though I'm not too certian how it works entirely :lol:
