macaroni
Anyone In Kent, West Preferably, Can Fit New Trailing Arm Bearings?
macaroni
Hi,
the rear suspension on my 205 squeaks after a few miles, and I know the n/s trailing arm bearing has a bit of play in it.
I have neither the time or the inclination to do this myself, so want to know if anyone round my way can do this?
I have a brand new set of OEM bearings, but can't find a garage, even french car specialists, near me who want to take the job on!
Dan Taylor greased up the beam a few years ago when resetting the ride height, so it should (!) be a straightforward job.
Happy to pay a going rate and help out in any way I can!
Cheers,
Antony
james_pug
I can do I'm in ashford, I will have a couple of rebuilt beams for sale soon if youd be intrested?
macaroni
Hi,
thanks for replying. Would fitting a rebuilt beam be more economical than fitting bearings to mine?
PM me if you want to give me some prices, or even broadcast them here if you like!
Were your beams rebuilt with pukka Pug parts?
Cheers,
Antony
Remember that depending how bad its got, your tube could be dead if the arm has worn through the bearing and into the tube.
If that's the case, it's not just a case of new bearings and a replacement shaft I'm afraid.
macaroni
Good point. As I said in my OP, Dan did say it wasn't too bad, but needed a new bearing a couple of years ago.
It starts to squeak after a few miles and now displays some obvious negative camber. Not much play in it though.
Maybe a fully rebuilt beam would be the best option. Need to talk prices!
Two years is a long time though, especially if it needed a bearing replacing back then...
macaroni
Just to update this, James_Pug did a great job on my beam, quick turnaround and great price. Top bloke.
Good luck with your V6 project mate!
