Lan
Brakes Firm Until Servo Comes On
Lan
Hi there i'm having some trouble with the brakes on my car, new m/c lines etc... bled nicely
nice firm pedal, until I start the engine and the servo comes into play I then have a pedal with lots of travel which is significantly softer
I've periodically checked all the lines and bled the brakes and I still have this issue the brakes feel spot on without the engine running and then crap thereafter
any help appreciated
thanks
Lan
rallyeash
what calipers and master cylinder you using?
obviously the pedal drops down with the engine running as the pedal gets "pumped" up when the servo isnt getting any vaccum. (ie engine off)
Cameron
Sounds normal to me! :wacko:
Unless it's really spongey or going to the floor, servo'd brakes are normally a lot softer when the engine is running.
Lan
normal 19mm mc, good condition bendix front calpers, yeah i do expect that from servo'd brakes but i wasn't expecting this much travel its not all the way to the floor but its not far away either, ill check it over again when i'm home from work
rallyeash
normally will go down a couple of inch's
