boldy205
Intermediate Bearing
boldy205
Hi, just wondering if anyone had the bearing no for the intermediate bearing on the long drive shaft please? I tried a search on phone but no joy,
Many thanks
Matt op
Ryan
3247 03
about £25
boldy205
Thanks Ryan, but i ment the actual bearing No that is stamped on the bearing its self, as you can pick then up from a bearing supplier, generaly, much cheaper,
Anyone pretty please?
Thanks,
Matt
have a look on servicebox, the dimensions are listed and i do remember it is a fairly common size ive seen used on bikes, just cant remember the code.
easy to find which code you need from the dimensions on most online suppliers
Ryan
I don't have the actual bearing number, but the dimensions are listed as: 30x55-13, which looks like a common size, so you should be able to turn something up.
boldy205
Thanks for the advice, will try that size and see what turns up,
Matt
dch1950
Matt
600613-2RSC3 made in poland
Dave
