smithy
Coin Tray Spring
smithy
My coin tray was working fine now all of a sudden the spring has come off and vanished,for life of me can't find it so lid is all floppy now.
Anyone know where I can locate a replacement spring from don't suppose brabantia do them aswell do they?
wilyoldave
If someone doesnt mind sending me one I could get a load made as I work for a springmaker.
Wouldnt mind organising sending them out if there was enough interest.....
B)
chipstick
For £2, buy a whole new clip with spring in it.
Or if you must have it OEM, I have a spring and visit WSM fairly regularly.
rallysteve
Think he is referring to the spring which lifts the lid not the one in the clip.....
Steve
smithy
are you referring to the black plastic clip that holds lid closed? i have got a few of them as spares.
I am on about the spring that sits at rear and pushes lid up once released from the clip.
smithy
B)
if i can get hold of one i dont mind sending it for you to use as a pattern,i will try and find mine behind the dash again tomorrow.
wilyoldave
Ok mate - give me a shout and ill see what I can do.B)
Dave.
Ryan
I think I might have one or two spares, I'll have to check my big box of random bits...
smithy
if you dont mind mate thanks.......
chipstick
My mistake.
In that case, I don't think I have a spring at the back :lol:
My clip is broke, and I dont seem to remember it ever springing up when it has been released!
Henry Yorke
There is a little plastic bit on the lid that tends to crack and break off over time and the spring then disappears
Ryan
I could have sworn I had two of these in a little bag somewhere, but they're not with all my other pug bits, so they seem to have gone AWOL. :(
Pugs in Pieces
as Henry says, its most likely the little plastic clip has snapped off and the spring then does fcuk off! find a new bottom piece and fit another clip, although often easier said than done.
dizzy etc in post tomorrow by te way.
Obey_R
I didn't know there was a spring to hold it up either! I'll check that out...
wilyoldave
If there is a spring I should be able to get em made, so if someone can send one ill see what I can do :)
smithy
i will have to take it out to have a look at the plastic clip.
cheers will PM to confirm safe arrival of dizzy and hoses.
chipstick
I remember lifting mine up a while ago and something snapping off at the back, thought it was just part of the hinging!
Weser
did anything happen about this as I am after a coin tray spring!
