dodsworth_gti
306 Gti-6 Rear Brake Components
dodsworth_gti
hi all,my 306 has picked up a habit of throwing its rear pads out :angry
i know this is a 205 forum,but i trust the members on this forum :)
just wanted to know where the best place to get a new fitting kit from was??
i know peugeot sell them but i despise my local dealership :angry
many thanks
ben :)
If it is losing pads check that the cast carrier itself isn't worn. I have seen this in the past and no amount of fitting kits will sort it. Happens when the anti rattle springs are missing or fitted wrong, the pad then rattles about in the carrier wearing it out. The carrier bolts on so if it is this just get a better one from another caliper and bolt it on.
dodsworth_gti
the carrier is or apears to be fine but ill check it again
ive not had chance to fit a new fitting kit on it yet,just running bits and odds what i had laying about lol
id like to get a completely new set and hopefully have it sorted once and for all
is there no motor factors online that will sell them??
i know the ones in york dont
i did a search on the 306 forum which sent me to a motorfactors online which was very confusing and came up with a audi fitting kit,odd :lol:
i had this same problem with one of my 205s and a new fitting kit sorted it
dodsworth_gti
sorry,just found a kit on ebay
thanks for your help tom ill be sure to double check the carrier
also didnt know there was a right/wrong way of fitting the anti rattle springs
springs at the top, securing bar at the bottom, bit of lockwire helps retain the bar if you want to be sure it wont fall out.
I lockwire the pad locking bar in on my track day 205 after having the bar and pads get free at Cadwell Park. This was due to a worn carrier as I mentioned above, but I now lockwire them in on the track car just to make sure. Only an hours job to drill and lockwire both sides.
Paul_13
Have you been using the calipers out of your 205?
I remember that was spitting out pads, lost one at that meet ages ago :lo:
Check the pads too, I had a 1.6 front set with the edges worn so even with new sliders etc the pads where almost coming out with the wheel off
Daviewonder
I will second this. I had a pad fall out on the rear of my 106.
dodsworth_gti
its definatly not the carrier,can now confirm all is good there
got new pads and fitting kit ordered so hoping all is ok thanks guys :D
i should just sell it and get another 205 :ph34r:
S@m
My local factor carries the fitting kit, although i always ask for Saxo VTS rather than 306 since its the same calipers and confuses them less. Its about £6. I have an empty one in the car so i'll get a part number when i get a chance.
Sam
EDIT - scratch that, i should've read it all before i replied!
Edited by Sam306
