boldy205
Hi, i have just fitted a 2011 spec (plates on both sides of the diff) to my BE3 box, and upon trying to turn the road wheels when on axle stands there is a lot of resistance, (55Lb/Ft aprox when tested on a torque wrench)
The car is not in gear, i have tried slackening off the 3, 13mm speedo housing bolts which i presume is the only thing that preloads the diff bearings, its not the brakes tying, nor the intermediate bearing.
So unless its just a case of having to bed the diff in, im at a bit of a loss. I can see some thing burning out driving it as it is!
Thanks for looking
Matt
Sounds to me like the gearbox casing needs relieving somewhere.
boldy205
I have been an idiot, its seems the diff is touching the casing somewhere, as i slackened off the 8 diff cover bolts and 3 speedo drive bolts, and the wheels turn a LOT easier! Hope it hasent deformed the diff housing.
Does anyone know where these usually rub?
Matt
stu8v
You should easily see the witness marks on the casing I would have thought
boldy205
True, thanks for the replies, its back to the garage monday night for more tea and swearing then!
dimmapalmer
Just needs a little bit grinding out of the diff housing, had to do this on mine too.
boldy205
taken the diff out, again, looks quite thin where its rubbing though, maybe 4mm, and i guess i need to take out a good mm.
Thanks for the relpies
