backroadpug
Re Fitting Standard Seats
backroadpug
Hi all im fitting the standard GTI seats back in to my 205. Im i right on thinking there should be 2x plastic spacers under the subframe at the rear?
There is one spacer per bolt, so five per seat in total :)
backroadpug
mmm I can only find 4 god knows where the rest have gone altho its been 7 years.lol
Would it be ok to just bolt them straight to the floor or should i just make washers to the same size as the 4 i have.
Pugleyrich
Will be fine to the floor. Seen loads without for lower seating position
allye
They are fine without, I'v taken them out because I'm 6'5'! :lol:
McDude
I also took mine out to lower the seat (along with the tilting mechanism). I bought washers that were a similar size (on the face, not the depth), but it appears that this probably wasn't necessary.
I took mine out and replaced with penny washers to save that 3/8" or so.
However I would advise getting the penny washers, 205 seat mounting points on the body are not the strongest as it is, and its not unknown for them to crack, so better to spread the load with a washer, and Peugeot obviously thought so too, as otherwise they probably would not have fitted spacers.
tri_longer
I can vouch for that as a fornt end smash I had some years ago ripped the seat off two of the mounting points, so someting to bear i mind.
