Fox 3 Posted June 24, 2011 I need to swap the rear hatch on my 205, I've heard there is a loom connector tucked away somewhere for the wiper and lock etc. Where is it and how do I get to it? Share this post Link to post Share on other sites
j_turnell 134 3 Cars Posted June 24, 2011 Rear loom is behind the n/s/r light cluster, there are two plugs iirc white and yellow, then its just the washer pipe on the other side. Share this post Link to post Share on other sites
Fox 3 Posted June 24, 2011 Excellent! Thanks very much Share this post Link to post Share on other sites
Anthony 1,002 Posted June 24, 2011 Rear loom is behind the n/s/r light cluster, there are two plugs iirc white and yellow, then its just the washer pipe on the other side. There's a third 2-pin plug as well if you have central locking installed. The plugs are a tight squeeze to get out of the hole, but a bit of wiggling and they'll come through - there's no need to remove the plugs. Share this post Link to post Share on other sites
