Fox
Rear Hatch Multi-Plug
Fox
I need to swap the rear hatch on my 205, I've heard there is a loom connector tucked away somewhere for the wiper and lock etc. Where is it and how do I get to it?
j_turnell
Rear loom is behind the n/s/r light cluster, there are two plugs iirc white and yellow, then its just the washer pipe on the other side.
Fox
Excellent! Thanks very much
There's a third 2-pin plug as well if you have central locking installed.
The plugs are a tight squeeze to get out of the hole, but a bit of wiggling and they'll come through - there's no need to remove the plugs.
