smithy 1 Posted June 15, 2011 Apologies would have searched but cannot on iPhone. I am in process of getting 8valve engine out and was wondering how easy it is to remove the wiring harness out of car. It is completely disconnected engine side and brown plugs under dash,but the wiring to ECU goes up above steering column and feels like it is securely tied in place but cannot see where.is it straightforward to release wiring and after getting it free will the ECU plug actually fit through the hole in bulkhead? Share this post Link to post Share on other sites
Anthony 1,003 Posted June 15, 2011 You need to partly remove the dashboard to get the loom out intact, but that's actually surprisingly quick/easy. Once free, it will all go through the bulkhead hole just fine Share this post Link to post Share on other sites
smithy 1 Posted June 15, 2011 Thanks Anthony,is it just a case of top dash and clocks out or will there be more to remove? Share this post Link to post Share on other sites
Anthony 1,003 Posted June 15, 2011 From memory, it's just a case of instrument cowling, and undoing the various nuts/bolts that hold the main section of the dash in place so that you can pull it forward a few inches and draw the loom through and then bolt the dash back up and refit the cowling. It's been a while since I've done it, but I'm sure someone will confirm that there's nothing else that you need to do. Share this post Link to post Share on other sites
smithy 1 Posted June 15, 2011 thanks will give it a bash tomorrow. Share this post Link to post Share on other sites
smithy 1 Posted June 17, 2011 You were spot on Anthony had to unbolt and pull back dash enough to remove ECU mounting plate,I could then guide the loom out. Share this post Link to post Share on other sites
