m_attt
Dturbo Injector Leak
m_attt
hi,
noticed alot of fuel sprayed around the engine spanning from an injector, and also see it bubbling on blipping the throttle. So checked with a spanner and its deffintly done up tight.
so before i take it apart and lose use of the car as i need parts/leak gets worse, would anyone no if there are seals that are there to replace or is it a new injector.
regards
Matt
Paul_13
There are a few seals.
Injector seal and fire ring off the top of my head. 2 per cylinder
Ones copper and the other I believe composite (red in colour?).
Mikey S
injector leak off pipes often perish and split causing diesel leaks. check those before condeming the injector.
m_attt
ideal thanks mate, was hoping it would just be a seal. :)
m_attt
think its deffinatly the injector, can see bubbles and fuel coming out between the head and injector, and the spill offs are all dry
Mikey S
ok. i have known high pressure pipes to crack, usually if the fuel pump mounting bolts are either loose or missing.
m_attt
cheers for heads up, will check all those bolts while im there :)
