gaz832
Pugs Booked In To Be Sorted Proper
gaz832
ive had enough of trying to fix the pug myself, not throwing anymore money at it and getting nowhere, went to puegoet eccosse today and got it booked in for next friday. hopefully all the little niggly bits will be fixed and car will run properly.
monkee87
I know exactly how you feel. My car has been annoying me recently, so I took it off the road to sort it. :)
Started off wishing I hadn't as it was a horrendous amount of work. :( it's now been 2 weeks and the light is at the end of the tunnel, I should be finished tomorrow. :D
Just so you know what I've done - repaired all the wiring under the dash, put a phase 2 engine wiring loom on the car, changed the loom for the front lights, fitted a power steering setup (new rack, all the pipe work etc) new piping for the washer jets and new gaskets for the inlet manifold and the thermostat housing! :lol: probably more, but that's all I remember..
I'll be so happy if I can drive it tomorrow!
dcc
If i can get my front brake lines sort ill be able to drive mine soon too :) cant wait to feel the difference in having over double the horsepower!
mickie
i wish i had it in me to throw more money at the 205 and book it in somewhere but i havent.. sick of the thing now, the starter on mine constantly clicks, its got a fast constant click, ive beefed up the earths, the battery got 14v while engine on, ive changed the brushes in the starter and i still have a problem.. ive done a little searching on the forum but cant find anything and dont want to spend hours doing any more.. thats my little 205 story
Edited by mickie
gaz832
i know what u mean folks. everytime i fix something on the thing something else breaks. heres my list
new speedo cable
find where the oil leak is coming from.
mi16 engine in the car seems to be misfiring under load. ( changed the plugs ,leads usual stuff still hessitates.
heaters have now packed in.
if it gona break after that, i think i will be selling it or break it for bits.
jeremy
From past experience I have found that most of these starter problems stem from a poor feed to the solenoid even though it still has what you describe. Try taking another wire from the ignition key. Fairly easy to do, and cost just a few pounds. Since doing this to mine I have never experienced any further problems.
Alan_M
Same here.....for ages I had the clicky starter syndrome. Once I fitted a new wire from the under the dash to the starter solenoid, never had another problem!
