pugpete1108
Swapping Cams Etc From One Head To Another
pugpete1108
i am still unsure what the situation is with my head so was looking at buying a new head and rebuilding it with my cams, valves etc.
is this the correct thing to do? or is it a no no using the bits ( i know cams are ok)
also with regards to a 'tapping' head, how do i correct this?
or even doing a full head rebuild what is involved in this?
still weighing up the options tbh
smithy
So long as you lap valves in properly and then adjust the valve clearances afterwards it is not a problem.
Just make sure the new head comes with cam caps.
The tapping head sounds like valve clearance and would be cured by adjusting the shims.
Best bet is get a Haynes as it will explain how to do it.
Assume you are talking about an 8 valve?
Paul_13
Tapping head sounds like bent valves to be honest mate.
New valves really to correct the problem.
The smallest amount can cause the valve to tap against the seat, it'll keep tapping and tapping getting louder then the valve head will let go.
Head rebuild will consist of:
Possibly new valves or old ones will be checked for straightness
Valves guides check in the process
Aswell as bucket tappet condition and tolerances
New stem/cam seals- be silly not to
Valve seats reseated
Light skim
Pressure test and crack test
Condition of cam carrier bearing surfaces checked
Miles is a very good person to speak to about getting this work done, where I take my engine bits to be worked on.
On the other hand it could be a sticky tappet.
Do you know any history on the engine?
P.S O yeah centre cap turned up today mate, spot on
**** It's a GTI6 (XU10J4RS) Engine****
Edited by Paul_13
pugpete1108
Light skim
might just bolt mine back together and hope for the best then, if it leaks again i'll buy a new engine complete.
it wasnt really that tappy, just ticking slightly
there's a few low milage ones knocking about now.
no worries about the cap.
Edited by pugpete1108
