SurGie
Where's This Boot Come From,
SurGie
Hi Members,
As above really.
I need to know where this boot may have come from > th_HeatwrapprotectiveExhaustbulkheadarea.jpg
Picture courtesy of HERMAN, > Thanks :)
Iv not ever seen this on a 205 before and iv had a few. I would want it to help protect my new UJ from the 6 exhaust manifold heat. I guess with the extra weight of this engine, it can give the UJ more wear/use etc ?
Cheers G..
the factory...
Daviewonder
They all had them but most crack and split and fall in half.
More to the point what expansion tank is that? It looks like a phase 2 but it's the wrong colour.
that's what they come like now.
the boot was only found on non-pas columns, and is NFP.
Cameron
Yep, this was present on my 205 when I removed the steering column.
harryskid
I have a similar type of thing on my conversion but its home made and constructed of alloy!
SurGie
So just to summarize >
Where, as in what other car, drive-shaft, rack, etc could this type of boot be bought to replace it ?
Suggestions and pics if possible >
Paul_13
Extend the heatshield over like I have to cover it?
Or you thinking more of water ingress?
SurGie
Yeah everything really, ill be using a GTi 6 type of heat shield modified to fit how i want it to look, proper pro.
Ill be using some of THIS type of grease inside the boot. Its clings very well, i'm using it inside my beam with grease nipples, i have to sort beam my self due to funds.
Daviewonder
That grease sounds pretty good, might give it a go as I've got a beam rebuild coming up on my 1.6.
Thanks for the tip ;)
SurGie
No worries Daviewonder :)
Im using that stuff for everything that need to be greased as its also a high pressure type too.
Dont forget, i could still need a bit of copper brake pipe for when i get round to that job. So ill let you know if i do.
Daviewonder
Ok Mate no probs, just let me know what you need ;)
Mikey S
Ive got one a spare one Surgie ;)^_^
Edited by Mikey S
SurGie
Nice one :)
I was going to trawl the net for one from another car this week thats a similar kind of size, so you've saved me some time.
PM us your payment details etc and ill pay you as soon a. I'd need it posted if possible as it going to be fitted by next week.
Lan
why bother greasing inside of the boot youre not going to aid UJ lubrication as its sealed anyway, the only purpose of the boot as far as i can tell is to protect from water so maybe just put a dab of grease around the edges of the boot to seal it up a bit
SurGie
My last UJ went no doubt due to the car having the old iron block MI16 and as it didn't have any power steering i assume the extra weight put more strain on the UJ. Also it will help by giving more protection from the large manifold from the VTS engine.
Plus it makes it look neater.
Paul_13
I think you'll need to shield the grommet where the uj passes through the bulkhead, mine had started to bubble and only a matter of time before it set on fire.
SurGie
Off the top of my head i cant think what type of material i could use to shield it. Should i slip something into the edge of this grommet against the bulkhead ?
Guest
