Strictly_Derv
Info Needed
Strictly_Derv
I might be getting a set of Compomotive CX's 108x4 6j 13" does anyone know if they fit ok and what size spacers I need? I'm running 306 266 brakes up front and 205 GTI rears.
And would they look too small on my car?
Strictly_Derv
Edit - 243 brakes off a 306 Dturbo
What offset are they?
Original 13" rims clear the 247mm brakes as standard but I think some can have clearance problems when fitted with a vented disc i& caliper instead of solid, especially if not using the bendix calipers.
Graham.
Strictly_Derv
I'm quite certain they are Ford size after talking to my mate, he bought them off someone who had them on a 106 gti but don't know if he used spacers which he must of had to use as 13" steels have a 1mm space between the caliper.
I'll get getting them shortly to try out some tires on.. 165 70 13, hope they fit
I will let you know the offset then
Strictly_Derv
ok i've found written on the outter rim - 6.0j x 13 x 21-33 neg
in the inside found- w.21/5/88 but thats probably the date
