james306
Gearbox Mount
james306
Can anyone tell me if the gearbox mount in the 205 is the same as the one on the 306 as they look to be the same and I have a new 306 g/b mount sat in my garage?!
Save me having to get as far as trial fitting the mount and finding that it's a slightly different size.
Ryan
Servicebox says they're the same.
Very different, the 306 one has a larger hole in the middle
Ryan
Just double-checked and it's only some models that are the same, so best double check.
I believe the TU bush is the same as the 205, all the others as Miles said have a larger centre bore and have a big spacer tube over the stud.
edit, randomly ones from a 1.8 8valve 306 is the same part number, but none others :lol:
found on many other pugs, especially the 106, lots of 406's with ally block engines
Edited by welshpug
