Technik21
Air Horn
Technik21
Is the Gti air horn (not the compressor) serviceable?
I ask , as it's only emitting the higher note when used, and not both high and low.
I notice only one pipe connected to the horn from the compressor, but two connectors on the horn unit itself.
Sounds a bit 'woosy' at the moment :wacko:
peterjohnson6037
From the two connectors on the horn connected to the compressure it normally piggy backs to the second horn via a second
pipe, if this is missing the second horn won't work :)
feb
Spraying WD40 in it might help.
Technik21
Thanks, I will nip off to Halfords and get a T Junction to connect both horn connectors.
