SurGie 54 Posted May 26, 2011 Hi Member's, Iv rang Maplin the other day and asked if they sold as tool to hold two joining wires to be soldered together, to make the job far easier and to get a better soldering ready for a shrink wrap. Does anyone know of a tool like this or a good technique to help when soldering two wires together ? Cheers G. Share this post Link to post Share on other sites
welshpug 1,657 Posted May 26, 2011 http://www.vehicle-wiring-products.eu/VWP-onlinestore/terminalspreins/heatsealterms.php Share this post Link to post Share on other sites
Cameron 16 Posted May 26, 2011 Swing and a miss.. SurGie means - is there a tool that will hold the two wires in position so that you can solder the joint together, rather than having to try and hold the wires together AND solder them at the same time. I'll admit it's a bloody nightmare sometimes as you need 4 pairs of hands, so a tool that holds them would be great! However there's nothing stopping you from using a small pin vice to hold the wires together, or cobbling an array of pliers or something! Share this post Link to post Share on other sites
Rippthrough 98 Posted May 26, 2011 (edited) Two small crocodile clips tbh. Or the solder splices that Mei posted. Bit tricky getting the heat level right on those though. Edited May 26, 2011 by Rippthrough Share this post Link to post Share on other sites
McDude 33 Posted May 26, 2011 Get two crocodile clips and fix them each with a bit of speaker wire (or similar wire that is flexi but maintains shape) to a small bit of wood. Google "soldering clamps" and you'll see something similar but not quite as good as what I'm proposing. Share this post Link to post Share on other sites
Tom Fenton 1,541 Posted May 26, 2011 Strip wires, but do not twist. Push both ends together so the wires are "intermeshed" and splayed out slightly. Now keeping the two wires still twist the copper strands together. They will now hold together whilst you solder. Share this post Link to post Share on other sites
SurGie 54 Posted May 26, 2011 Thanks for the advice guys, yes Cam thats what i meant. I quite like the crocodile clips and some speaker/welding wire way. The wires i need to sort are very thin, so i think these ways would be the easiest. There's always a simple way, and there sure is Cheers G Share this post Link to post Share on other sites
Masekwm 2 Posted May 26, 2011 (edited) I used a vice and other appropriate tools The A4 paper is a print out of the GTi6 wiring guide from this forum Edited May 26, 2011 by Masekwm Share this post Link to post Share on other sites
smithy 1 Posted May 26, 2011 man after my own heart can of beer on the go while doing some work Share this post Link to post Share on other sites
Alastairh 47 Posted May 26, 2011 Strip wires, but do not twist. Push both ends together so the wires are "intermeshed" and splayed out slightly. Now keeping the two wires still twist the copper strands together. They will now hold together whilst you solder. Spot on! Plenty of practice is the key! Share this post Link to post Share on other sites
welshpug 1,657 Posted May 26, 2011 I do much as Tom mentioned, don't forget to slide on the piece of heat shrink tubing beforehand, and place it well away form the joint or it'll just shrink in place Share this post Link to post Share on other sites
SurGie 54 Posted May 26, 2011 man after my own heart can of beer on the go while doing some work Some cat munchies as well, cant be bad Spot on! Plenty of practice is the key! I did originally do it in a similar way to Tom's but for one the wires were to thin and the other it just took too much time, it started to get annoying with them coming apart every so often. As well as the wires were in the engine bay attached so was harder to turn the wire all the way round. Thanks for the help guys. Share this post Link to post Share on other sites
Cameron 16 Posted May 26, 2011 I do much as Tom mentioned, don't forget to slide on the piece of heat shrink tubing beforehand, and place it well away form the joint or it'll just shrink in place Ergh.. the amount of times I've forgotten to put heatshrink over beforehand. Share this post Link to post Share on other sites
